Old 05-22-2007, 07:56 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Default Jaguar rear E-Brake and rear caliper help?
I'm about to start working on the rear brake setup in my Jag-reared Contemporary. My emergency brake setup is COMPLETELY backward - the handle is on the drivers side of the tunnel. The E-Brake caliper that the outer sheath of the cable is mounted to is on the driver side, and the E-Brake caliper with the inner core of the cable attached is on the Passenger side. I want to put the handle in it's correct position on the passenger side, which means I have to disassemble the entire brake setup and swap the E brake calipers, no? Can the E brake calipers be swapped without removing the brake calipers? This whole rear setup is like nothing else I've ever seen. Anyone got any ideas? Any easy tips on an easy way to remove the rear calipers and E-brake system? Are they infact usable on either side?
