Old 05-23-2007, 09:52 AM
Rick Parker's Avatar
Use an OHM meter and check the coil wire and Plug wires. The rotor should be touching but not grinding. Is the coil actually listed as compatable with the MSD box you are using? What plug gaps are you using?
Rick
