Old 05-23-2007, 07:51 PM
bmwdb10's Avatar
bmwdb10 bmwdb10 is offline
Cobra Make, Engine: Gulf GT40 CAV137, Cobra ERA286
Marty,
The rear window should come with the aluminum frame that screws to the pinch weld on the body. The window is slightly oversized to the body so it must be sanded or ground to fit. I simply used a block with 80 grit paper until it fit snuggly over the frame and even to the body surface. It was held into place with 4 aluminum tabs riveted to the body with auto body attachment tape on the bottom of the tab. The rivets were easy to drill out for occasional cleaning of the plexi. Boy... memories!
Gulf GT40 CAV137
427 Cobra ERA286
