Speed Sensor
Does anyone know of a speed sensor that I can use in a Supra Turbo(R154) gearbox. As the orignal one sticks out from side of the gearbox a fair bit it hits the chassis so I removed it and used the ABS speed sensor. The problem is that it appears the signal from the ABS speed sensor saturates at around 70 kph and speedo stops working.
Is anyone aware of a lower profile VSS that will fit into the Supra gearbox.
I tried to fit a right angle drive but it still hit the chassis.
Warren
