Originally Posted by CobraCurtis
I have an oil leak and could be either the oil pan or the main seal or both. I have had the oil pan gasket changed twice and it is still leaking. To make matters worse, I think I have the 2-piece seal and need someone who can change it while the oil pan is removed and without removing the motor, if needed. It just started leaking more so I have decided to no longer ignore it. Anybody know a good mechanic that I can trust to take care of my problem?
Thanks
Did you find a good mechanic?? I could use one myself..
