Originally Posted by sideshow
so all u want is the left over wires for
speedo
tacho
fuelpump relay trigger
fan relay trigger
accell pedal wiring
batt
ign
brake signal
obd2 diagnostic plug
mas air flow meter
air temp sensor
and maybe rear o2 sensors
do u have rear o2 sensors maybe speak to engineer if they are needed
you would only need 2 or 3 fuses on the bat and ign wires
the other fuses u have to fit them on the relay to the fans and fuel pump
i doubt the ecu has a check engine light cause everything is serial data to the bcm the pim and the dash
anyway ill keep intouch when i get the plugs
thanks
jim
Jim,
sounds fantastic. What are the other wires used for on the standard dash loom that we are "losing" ???
Les,
There was NEVER any doubt about the MIGHTY MAROONS!!!
What did you New Southerners think of the game???
