Old 05-25-2007, 03:50 AM
Rebel1 Rebel1 is offline
Darrell, Are your lower arms the same length?
Also check your drive shafts are the same length.
Minor differences have a huge effect.
Check the diff is in the center of the car...I'd be surprised if it wasn't.
Then check that your brake rotor is centered in the caliper. If not, adjust with shims between diff and rotor. I think the allowable difference is 5 thou. measured at the lugs on the inside of the caliper.
Camber is adjusted by adding/subtracting shims between the rotor and the drive shaft flange.
Best of luck
