Old 05-27-2007, 01:34 AM
stephen low's Avatar
stephen low stephen low is offline
Ross
I bought the larger of the two pinchwed seals with the moulded rubber O seal attached, but found this is too large for the bonnet and boot to shut properly. Did you use pinchwed with any rubber seal attached, and if so which one?
I'd like to have some form of rubber attached to the pinch component of the seal so that any rubbing will be less severe on the paintwork when done.
Have you any pics in your gallery of the seals you used?
slowy
