Old 05-29-2007, 01:34 AM
Keithc8 Keithc8 is offline
Default Crankshaft drilling
You do not want to cross drill the crankshaft. This was mainly done because of the design of the old cranks and this was one of the only ways to get the oil to the center of the crankshaft where the oil holes for the rods had been drilled to. You need to use the NASCAR style as it is referred to most of the time which is pretty much the way all of the SBC and SBF stuff was drilled. If you are using a good crankshaft company they should know all about this. I keep a lot of billit Scat crankshafts in stock. Thanks, Keith Craft
Keith C
