05-29-2007, 03:06 AM
QLD
Originally Posted by macloft
Schipps
mine also hits the door top. Warrick showed me how, by undoing 2 screws holding a Y shape plate in, you can get at a small screw which attaches the inner steel shaft to the light switch. Undo this screw and presto the whole stalk comes out. You then shorten up the stalk make a new spacer (throw away the plastic part) and you ahve a shortened indicator stalk.
Bruce,
Thanks, I Will be slipping out to the shed to do that shortly, after I saw Geof's picture I was certain I had the wrong model laser column.
Mick
Schipps
