Suspension
Do the shocks have bump and rebound adjustment and if so are they set the same? Do you have spherical bearings in both ends of the shock and if so are they binding? Look for anything that might introduce "stiction" in the system.
Both shocks should have identical characteristics in bump and rebound. If all the suspension components (upper and lower arms and anti roll bars) are free in movement you might want to take a hard look at the shock. If some one has a shock dyno in your area, it will tell you a lot about balance between the two front shocks. I had this problem once and it was the lower a arm binding in it's bushings.
