Clearance
It's the other way around, the block grows more than the push rods therefore valve lash increases with temperature IE the head moves away from the crank as the deck goes up from thermal expansion. The push rods are steel and their thermal rate of expansion is much lower so they stay about the same length and clearance between the rocker and push rod increases.
