Guys,
I would like to move the shoulder belt attachment points higher up...at least as high as my shoulders.
This bar is from Finish Line...on my FIA car the belts would need to be offset to the right to fit evenly over my shoulders.
(Some of the cars have mounted the seat offset to the right, at an angle, to maximize leg room...mine is as far as practible to the left to be more directly behind the pedals/wheel.)
Does anyone make a bolt on bar that allows the belt attach points to be MOVED to the right?
Everything I have seen has the belt attach pts inside the "hoop"...I need it to be in the "center" for the right belt, about and "inch or two" outside of the hoop on the left belt
The photo did not appear in the preview...maybe it will show after I submit the post, otherwise, go to:
http://www.finishlineaccessories.com...ge.php?pID=219
Thanks,
Pete
