I have a sleeve in number 3. There was a rust hole from the back side that appeared after boring it .030 over. Made over 570 hp on pump gas on the dyno (solid lifter cam at only 6,000 rpm). If the machine shop knows what is doing, don't worry. Should only cost you $150 per sleeve with machining, labor, and material.
