Would the FinshLine bar work?
Red,
The more I look at your setup, it should work.
If the seat on your 427" SPF is about in the same relative position to the seat as in the ERA 289", then all I would need is the inner shoulder harness belt setup to loop over the roll-bar cross-member.
The outer mount can hang on the outside of the bracket, maybe even get spaced another 1/2 inch or so with out wild bending moments...?
I have been thinking about getting wider shoulder harness belts anyway, so this modification may get me off the mark.
Pete
ERA 289 #2027
