Old 06-03-2007, 05:57 AM
snaken's Avatar
snaken snaken is offline
Cobra Make, Engine: Homebush, Dodge Viper blue, white stripes, black traditional interior 347, AFR heads, Morrison injection, motec, T5, live axle, lead car Bathurst drivers parade 1999, 5.0L Cobra Nationals sprint title 2001
Question cam choice 347 Windsor
Hi Fellow Engine Builder Technocrats,
Well the new Ford Motor Sport 347 short block has arrived. AFR CNC machined 185 heads are ordered with spring upgrade and roller rockers.
Time to select the cam
This motor has individual 44mm throttle bodies, 36 lb injectors controlled by M48 MoTeC. Compression will be about 10.5, pistons are fly cut to suit inline valves of the AFR heads.
Running 5 speed, diff ratio 3.93, so engine will need to rev. The throttle bodies really smoothed out the old E303 cam. Looking for rough idle, good mid range torque and top end power. This cobra is driven hard on track days, very little road use these days. Was looking at a stage two cam, 224 / 232 at 50 thou, but think I could go a step bigger to make the most of the airflow from the throttle bodies and heads. Looking to make 420 + HP without excessive revs, below 6500 rpm.
Anyone got a perfect cam for this combination?
SNAKEN
