I like the setup. the fittings in the back are vacuum fittings also, maybe the distributor does not need as strong of a signal as power brakes need. If you remove the vacuun setup(if it is not needed on your car) you can just plug the fittings on the manifold , it will look cleaner. I would be interested in buying the vacuum setup if you do not need it. My GT40 has power brakes.
