Old 06-03-2007, 03:58 PM
PJ10 PJ10 is offline
Default Possible short/bad altenator
Just a guess, but I assume you have a seperate voltage regulator. Since this all started happening when you replaced the voltage regulator (also, why did you replace it, was it bad?) I suspect that the amp meter is not showing the correct charge, matter of fact, I bet if you could measure the current another way, you may have a discharge situation that is stealing enough voltage from your electrical system and causing an inadequate spark. This could explain rough idle. Check your voltage on the coil at idle. If you are reading 13+ volts, your charging circuit is fine. If not, you could have a bad alt or regulator.
