Originally Posted by Cashburn
What cable, spring kit, carb bracket, are you running? Also how is your cable routed? Is it catching on the carpet or simply the cable and/or springs binding? Also check the pivot rod of the pedal assembly to verify it is not too tight and binding there.
Don't know what cable, was assuming it was a BDR factory item? Car was assembled by Custom Cars. It looks like stainless steel braided something. The springs are big one on the outside and smaller inside. Carb bracket is a CSR 620 unit. Cable looks like it has nice curve from carb to the throttle bracket. The cable is not frayed from what I see exposed. it is not catching on floor mat or side carpet. Did notice that the s.s. braided tubing looks like its compressing/distorting at almost WOT?
