Old 06-03-2007, 08:32 PM
KitCarstoGo KitCarstoGo is offline
Arrow NEW Company Needs Opinions Please,
Hello Everyone,
Brian here with Kitcarstogo, I've been purchasing my door hinges from IWC and we have been installing them into the 1 by 1 frame that supports the body. I've noticed the positioning has to be so precise or else the Doors want to scrub as they open. In some incedents the hood/trunk also. I've noticed so many other factories hand lay the mounting brackets into the body. Is this why they do that? Does that eliminate the too close fitting issue. It just seems that the hinges (Cold rolled steele resembling a half loop) would fit better if mounted almost level with the object they are lifting, "Correct"?
Any help is a blessing, Thank you so much.
Brian
