Old 06-04-2007, 03:48 AM
Ant Ant is offline
Default Pin drive "pins"
Pin drive pins has anyone made their own larger pins to suit a one piece hub, and to suit the five pin common adapter type wheels?
To make it clearer I have a set of Compomotive pin drive wheels, but due to the extremely wide track of my Cobra I need to make one piece hubs up, and I have two options,
Make hub up and drill to fit OEM wheel stud and Trigo/Compomotive screw on tapered base pin.
Make a larger (3/4" OD) version of the 6 pin style pin which is 1/2" OD and has a 3/8" shank/thread, there may be a problem tightening as I wont have an internal drive in the pin to either screw it in to the hub, or hold it while I screw a retaining nut up!
A J. Newton
The 1960's rocked!
