  #31 (permalink)
Old 06-05-2007, 06:18 PM
dvcobra dvcobra is offline
Cobra Make, Engine: Classic Roadster 427SC, 351W bored .30, Edelbrock Performer RPM Package, Tremec trans, Currie 9" rear end.
Don, what about the carrera setup with tubular control arms that you used to recommend from Bethania Garage? The only problem I have had with this setup is the adjustability of the shocks for the track. I have to remove everything to adjust and then my corner weight balancing is all off. I also haven't been able to find a spring compressor that works in the limited space I have to work with. It takes a long time to adjust the springs at 1/8 turn at a time.
