Old 06-05-2007, 06:40 PM
Kenm4187's Avatar
Kenm4187 Kenm4187 is offline
Cobra Make, Engine: SPF# 2560
Default Rear Diff. Removal
It looks like I need to pull the Dana rear differential (limited slip not working). I can see where the half shafts unbolt and how to get to the rear diff. mount, but I am not sure where is the best place to come apart in the front end. It looks like it can unbolt at the driveline brake but I'm not sure. If I pull the drive shaft out at the tranny it looks like I will loose the tranny fluid.
Bottom line, what's the easy way to pull it out?
Thanks,
Ken 2560
