GOOD LUCK!
I wanted to do the same thing, and it took myself and a friend over 200 hours of work to do it EXACTLY the way we wanted on my Lonestar body.
Essentially, here's the steps we went through...
1) Sand the gel coat all over with 80 grit.
2) Fill in and shape anywhere that it 'feels' flat, with bondo (or "kitty hair" if you need large areas filled or shaped). Allow to harden
3) Sand down with 80 grit again
4) Repeat step 2 as many times as you can stand
5) Sand down with 120 grit
6) Repeat step 2 again and then step 5 again until you think ALL the flat areas are gone and it 'feels' smooth all over
7) Spray with 'thick' primer, and then 'dust' with a contrasting spray paint 'marker'
8) Sand down with 150 grit to identify flat spots where the spray paint 'marker' shows through
9) Repeat step 7 again (with bondo where necessary, and as many times as necessary!!!)
10) Repeat step 9 with 200 grit until you think ALL the flat areas are gone and it 'feels' smooth all over
11) Repeat step 7 again
12) Repeat step 9 with 400 grit wet and dry (wet) etc.
We used 2-3 GALLONS of bondo and sanded most of it off. I felt like Daniel-san on The Karate Kid before we had finished..."spray on...wipe off", but the end result was PHENOMENAL. The guy who helped me used to run his own paint and body business and he was amazingly anal retentive about 'feel' and insisted on multiple coats of everything, with rubbing down with increasingly higher number sandpapers. I think we actually put on 12 coats of primer in the end.
It didn't get much better when we'd painted it (3 coats of paint and 3 coats of clear), and our final 'rub down' (before polishing compound) was with 3000 grit!!!! (25 sanding disks for $80...who knew you could even GET 3000 grit?????).
LOTS of work, and probably more than even a GREAT paint shop would do, but the finish is superb.
GOOD LUCK
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
