Thread: Cold Blooded FE
Old 06-06-2007, 07:48 AM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Default Dog, You bascially have a similar Shelby that I do
Originally Posted by Bluedog
Does anyone have any suggestions on starting an FE when it's cold? Since, my Holly Double Pumper 750 doesn't have a choke, I'm having a devil of a time starting the engine when its cold...cold is relative living in Cali and it's 75degrees! I've pumped the gas pedal, I've kept the pedal down and nothing seems to work. It takes me cranking on the starter for 5 minutes before she starts. Once the engine is warm, I have no trouble idling at 1K RPMs.
Would using a little starter fluid in the carb before cranking the starter help? How about covering the butterflys with a board to simulate a choke? All suggestions welcomed!
Thanks!
I have a CSX with a Pond 482/Bigs 750cfm HP. Does take 2 to 3 miles to warm up.
Steps to starting:
1. Turn switch on
2. Turn on electric pumps. Wait 10 seconds for pressure to build up and the fuel to get to the carb.
3. Press the gas pedal down twice (2 times then off).
4. Hit the starter, when it pops give it a little gas and feather the gas peddle to get it up to 1500 RPM to warm up.
If this does not work then look at the carb adjustment.
Morgan LeBlanc
Fresno CA
