Thread: LS1 and L76
  #21 (permalink)
Old 06-07-2007, 09:25 PM
Rebel1 Rebel1 is offline
Mike, why would you want to run two walbro pumps?. Why not the Bosch 040 which is advertised as below? :
In tank 600hp fuel pump 040 model
This pump is a Bosch K-Jetronic pump which is capable of pumping efficiently at high fuel pressures and suits high boost , high flow applications. It has a built in strainer on the base of the pump and can usually be adapted to suit most in-tank applications. It is commonly called an Audi Motorsport pump by people in the trade. It has similar physical dimensions to the external Bosch motorsport pumps but is a little shorter.This unit is the In-Tank version of the Bosch 044 Motorsport Pump.
