Old 06-10-2007, 03:49 PM
kinglenario kinglenario is offline
Default Superformance Clutch Adjustment
Hi, i just had my engine rebuilt and now it's going into first a little hard. it was fine before the engine came out and the clutch engages very soon so i suspect a little clutch adjustment should cure the problem. i pulled the little cover off on the inside of the driver side wheel well and bled the system although i thought there would be an adjustment there. also i checked at the transmission and there was no adjustment. Is there an adjustment on this system?
Thanks!
