Old 06-10-2007, 09:32 PM
ellobo11 ellobo11 is offline
Default Torsen t2r
Claykos,
I would be interested in knowing if you still have parts available for sale. My email address is jamesvfiore@yahoo.com. Hope to hear from you soon.
James
Originally Posted by claykos
After years of developing our roadster race car we have accumulated a lot of parts. All parts are located in Tucson and in good used condition. Here is a list off the top of my head, we probably have more stuff so if anybody is local and wants to come look around, shoot me an email. If you want something make an offer. I have usually sold used parts for 60-70% new cost depending on condition.
Conctact: claykos "at" cox.net
Fuel cell - the one included in spec racer kit
8.8 Torsen T2R limited slip rear axle (3.5:1) with Wilwood 12" disc brakes and Gordon Levy 3 link setup with watts. Basically brand new
Baer "Pro" Front brake kit: 13" custom floating rotors by hrpworld.com, Alcon 4 pot radial mount calipers, spindles, hubs, etc. 4 lug setup. Extra pads.
Front and rear brakes (Baer "touring" kit) complete, but smaller than above brake setup (11" - 1 piston rear, 12" -2 piston front calipers) PBR Calipers.
Various Eibach Springs
Pro shocks
2 different master cylinder setups: single master cylinder and dual CNC setup with balance bar
Handbrake lever and cable
Quartermaster 8.5" dual disk clutch (new disks) and aluminum flywheel with starter motor and new throwout bearing. Weighs 20lbs, holds 800hp street drivable.
Complete Accusump System with electric Valve
Complete external oil pump wet sump system with custom pan.
Lakewood Scattershield and clutch lever (new) for clutch described above
Brake and clutch pedal assembly (Mustang)
Shift lever
Shift boots
Set of 17" Roh 5 spoke 4 lug wheels and Kumho Victoracer tires (tires are pretty old, but have tread left)
8 4-lug wheel centers to build 3 piece wheels by Complete Custom Wheels
