My car number is 1738. it was put together by dynamic in ohio. The engine is a Ford Motorsport 392. I'm not sure of the model Tremec.
i have been under the car and bled the slave cylinder by the bell housing, and i also bled the other slave cylinder behind the drivers side fender. The system has no air! the problem is the adjustment. The rod that comes out of the slave cylinder by the bell housing has no adjustment! there has got to be an adjustment somewhere. right now there is a huge difference between having the clutch ALL the way to the floor, or 1/8 inch from the floor.
