Old 06-13-2007, 08:31 AM
Bart Carter Bart Carter is offline
Cobra Make, Engine: Levy Racing built FFR w/351W
Originally Posted by Enormus
Firstly,
I there a dry sump system for a 460 and who makes it. Is it worth it to have it installed.
Secondly
I was told it was not nessary to install an oil cooler as I have a larger radiator, I live in Vancouver Bc but it still get hot here.
Can I install a oil cooler with thermastate control or is all this to complicated
Norm
I live in Las Vegas, where it reaches 120 degrees. If you do not track the car, you do not need an oil cooler. Check your oil temps when you drive. I'm sure you will never see over 250 degrees. If your engine doesn't see over 6,000 RPM, you may not see over 250 at the track. Use synthetic oil and relax.
Bart Carter
FFR 4001
