Old 08-03-2001, 07:29 PM
coyled coyled is offline
Grant, it sound like a fun car to drive once that motor is in it. I'm still sort of curious. Does your throttle body flow as much cfm as the carb?Also, Kinsler has told me that with a carb you have to run it rich enough to cover your leanest cylinder. But, with EFI, you can run it leaner (as fuel distribution is much better) and not risk burnig a piston, which in theory should make more power. Well, so much for theory. Anyway, the difference in feel between 575 and 600 hp is probably not perceptable. You'll be hanging on as it will be a white knuckle ride either way. scott
