It has been done, but custom only. Nothing 'factory'.
The ones I've seen have needed extra long 'runners' (webers don't sit down as close to the port as other FE weber intakes) due to the TP's port arrangement and needing to 'spread' the ports apart to IDA spacing.
Why would you want one? The only webers that would be able to handle the TP's breathing capability would be 58mm's.
If you want the individual TB, Ford did cast some crossram TP intakes for use with individual throttle bodies and mechanical injection. Dove makes repros of those. Again, Ford probably did that due to weber limitations on a racing TP engine.
