Thread: Nose
Old 06-15-2007, 05:18 PM
tman8 tman8 is offline
Cobra Make, Engine: B&B 302 GT40, T5 5sp, 9"rear end
Originally Posted by duke
I had a lot of body dimension variations. Nose was off, hood scoop etc. Spending a lot of time filling with fiberglass and blending. Regarding the doors look at the previous posts. DO NOT USE any of the B&B mounting holes. Make sure to line up the wheel wells on the tires to get the proper centering. Regarding the doors, hang the hinges and adjust best you can. Remove the 2-3 screws that B&B used to mountthe body under the door and push-pull the body to match the doors. The re-drill and bolt it down. Saves you lots of time and filler.
Thanks, I will try that sounds like a good fix.
