Old 06-18-2007, 10:20 AM
427SnakeSC's Avatar
427SnakeSC 427SnakeSC is offline
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
Cool
I store mine for about 4 mths out of the year. I keep gas in the tank with fuel stabilizer. Before I store it, I put the stab in and run it for a few minutes to get the stabilized fuel into the carb. Then I fog the engine with Dexron II. I then drop the oil and filter and replace with new oil and filter. When you are running it that last time, just before you drop the oil, I run some Dexron in the crank case to flush out any sludge and it thins the oil a little so you get a better cleaning. I don't normally put it up on blocks, but if you are going to be gone a year+ you might want to put it up on stands. Might want to put a little Methyl Hydrate in the fuel to keep the moisture problem down to a minimum.
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
