I think all of the flanges are the same on this type. Try a wrecking yard for a rear driveshaft flange from a MK IV Lincoln with a 460 and you will get the round flange that bolts to your pinion flange and it will be set up for the large u-joint. It would not hurt to make a good sketch of the pinion flange w/ measurements to make sure thet the DS flange will work. If there is a tag on the differential, post all the numbers and I can find out where it came from and maybe steer you the right direction!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
