Old 06-18-2007, 12:16 PM
427SnakeSC's Avatar
427SnakeSC 427SnakeSC is offline
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
Not the rust you are concerned with. When gas sits in the tank for a while, condensation comes from the air. Water droplets form and drip into the tank. When that water tries to go through the carb, it isn't going to happen! Methyl Hydrate is an alcohol that will mix with the water and gas and burn the water off. I raises your octane a bit too. Should be able to get it in most automotive stores.
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
