Old 06-19-2007, 09:00 AM
Dwight's Avatar
Dwight Dwight is offline
Smile Lots of low end torque
I have a 5.0 1996 block with a 354 stroker kit, 3.47" x 4.03" with 5.4 rods,
EFI, 90 mm mass air, 70mm TB, 36 lb injectors, 255 lph pump, tuned SCT chip, Holley systmax upper and lower plenum,
190cc Pro Comp aluminum heads 2.02 - 1.6, 10.7 - 1 cr.
1.7 roller rockers,
1 5/8" headers,
Comp cam 35-518-8 fw XE274HR-12
gross valve lift int .555 ex .565 (with 1.7 .590 int, .600 ex)
duration @ .006 tappet lift 274 in ex 282
valve timing @.006 open close
int 29 BTDC 65 ABDC
ex 77 BBDC 25 ATDC
these specs are for cam installed @108 intake center line
int ex
duration @ .05 224 232
lobe lift .3480 .3540
lobe separation .112
Dwight
I'm doing a little research on cams. I think I need larger throttle body and a different cam to move the power up, closer to 6000 rpms. But I must say this motor has "lots" of torque at 1500 rpms. Pulls like a freight train to 5500. I have to shift at 5500 - 5800 rpms. I had to change the way I drive. I can now cruise at 1300-1500 easily in 5th and I do not have to downshift to speed up. Very nice. I'm going to drive it till winter and then decide if I want to change the cam. df
323 rwhp and 375 rwtq
