Old 06-24-2007, 07:40 PM
tamanaco's Avatar
tamanaco tamanaco is offline
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default loosing front mount differential carrier bolt
looking for help...over the winter installed a 3.91 rear end, when removing the old 3.15 ratio found the 14mm allen bolt to be loose??? At installation of the new 3.91 torqued the 14mm allen to BMW manual spec's of 70 FT/LBS. 1000 miles later a slight banging sound...checked out the noise...the allen bolt is loose again??? From the factory, no washer or lock washer on the bolt? Does it need some thread lock stuff, other problems?
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
