Old 06-24-2007, 07:51 PM
olddog olddog is offline
It depends on what you plan to use in the build. Aftermarket heads, intake, cam, and stroker rotating assembly, and your pretty much left with only using the block.
Give a $100 and you should get that back for scrap metal when you take the car in. So you would only have time and gasoline invested.
