There is a negitive (-.350") clearance to the front caliper, so there is no problem with caliper/wheel interference. I will be machining all 4 wheel for adaptor clearance. That is, the adaptor will be flush with the inside of the wheel for the maximum front spacing (4.0"). Front spacing is a problem with all Corvette C type of suspension because it is much wider.
