Hi Andrew,
Tough one mate as most bodies are slightly different.Mine is 210mm up from the sill and 535mm forward of the door opening to the lower rear corner of the vent opening.
With the over rider holes I lined up the mounting brackets as best I could,drilled small hole then gradually enlarge it to line up.Have a few beers first,makes you more relaxed before you start drilling!
Brett
