Old 06-27-2007, 10:24 AM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Default Driveline/Differential Decisions
Time to procure that ERA rear suspension for my 289 FIA!
Bob, I have some questions:
I'm leaning toward a Tremec 5-speed. Summit lists three different gear ratios. With my objective being streetable drivability plus some "spirited back country windy road driving" can you recommend which ratio I should choose?
Also, with the transmission choice picked out, what differential gear ratio should I run?
I'll be calling Peter for a quote for the rear suspension plus some other goodies.
Anyone else have recommendations for the Tremec 5-speed? Which gear ratios did you select and why. What differential gear ratio are you running?
By the way, the power plant will likely be a 347 @ 425 bhp.
Dangerous Doug
Dangerous Doug
"You're kidding, right?"
