06-27-2007, 05:44 PM
CA
The wheel hop you mentioned earlier on the Jag rear.I fixed mine by mounting the lower control arms on opposite sides and adding a rearward control arm from the original mount (now facing back) to the frameas far back as I could get.It has worked great for many years and does give you a little toe tweeking if you use left and right heim(rose) joints
