Old 06-27-2007, 09:32 PM
DavidinDurango's Avatar
DavidinDurango DavidinDurango is offline
Sounds like your final drive is too high for your tastes.
What ratio are you running?
Tire diameter?
Trans ratios?
I can put them in a spreadsheet and give you some idea what to change.
My kirkham is a 3.55 final drive, TKO 600 (.82 fifth) and billboard Goodyears - I'm right on the speedlimit at about 2100.
Originally Posted by ENTDOC
I realize we all like some noise in our cars , however I think the exaust and engine noise in my car is excessive. Have any of you guys added any sound deadener to the interior to your car and if so, what did you use? I am thinking of pulling the carpet and adding a dynamat type product and some neoprene and then putting the carpet back on. Also the heat gain around the footbox and firewall could be improved.
Second question: Have any of you changed to a TKO from a T56? Sixth gear is fairly worthless below 80 and first gear is too high in the T56 for me.
DavidinDurango
mostly fords, with "some stuff"
