Thread: Accusump kits
Old 06-28-2007, 08:18 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
TC---I have SPF #770, and have owned it from new now almost seven years. I have installed a 3qt Accusump on my stroked 351W not so much for pre-oiling, but to cover me in track events.
I took some in-car video during one of Olthoff Racing's Virginia International Raceway events about 5 years ago. I sent the raw video to Olthoff's to be used in a DVD they were making of the event. As Dave was watching the raw video he noticed my oil pressure was dropping to 10 psi, or less, in Oak Tree and Carousel turns. He pointed it out and said I ought to investiate an Accusump installation as well as an oil pan with better baffling. After some more discussions with Dennis Olthoff, I chose the 3qt Accusump system, with electric valve and one of Canton's "trap door" baffled 7 qt oil pans.
The electric valve comes on automatically whenever I turn on the ignition. This causes trapped oil in the Accusump to be forced into the clean oil input of the Canton remote adapter plate...so it's just like the oil pickup has suddenly been immersed in more oil, and all internal oil galleries get evenly pressurized. The electric valve senses low oil pressure on the engine side and opens to let the oil accummulated in the Accusump be forced into the oil galleries. Once the engine oil pressure returns, the valve senses low pressure on the tank side of the valve and opens another valve to allow oil to pressurize the cannister. Once the oil pressure is equalized on both sides of the valve, the valve closes and waits for an oil pressure drop on either side of it again. It's pretty simple and works great.
The Canton baffled pan is another step to keep the oil pooled around the oil pickup. There are a series of four doors that are hinged to keep the oil in a small diamond shaped box around the oil pickup. The doors all hinge inward toward the pick up to allow oil into the box, but will not swing outward. Once the oil is in the box structure, it's picked up by the oil pump pickup.
Either one of these devices is better than nothing, but both together are about as good as we're gonna get it without going to a full dry-sump system. Those are available, but not cheap, and the plumbing and oil tank presents another level of complication...at least in my opinion.
The choice is yours...but if you're primarily interested in pre-oiling, then an Accusump unit is the way to go.
Hope this helps, brother... I've had lots of experience with my SPF in six and a half years of ownership. I'd do it all over again...! I'm a very "gruntled" owner..
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
