Old 06-30-2007, 02:37 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Right side wiring.
Engine compartment view, right side:
Cockpit view. At this time, if you are running a MSD (we recommend the Digital 6 Plus) then you will need to run the coil leads and the distributor lead out along with the rest of the wires.
Now let's get the fuse box, power outlet, and main bus fuse (very important) bolted up to the under side of the right foot box.
Now you can bolt in your MSD box.
