  #25 (permalink)
Old 06-30-2007, 07:43 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Here are all the pieces you will need to complete your pedal box.
Here are your bolts.
Here are your parts. We call them the pedal box guts.
If you look closely at the brake and clutch pedal arms, you can see we drilled two holes in them. That way both pedals can be used for either the brake or the clutch arm. The upper hole (the one towards the part you push on with your foot) is used to hook to the clutch master cylinder. The lower hole is used to hook to the brake master cylinders balance bar assembly.
