Which TKO do you have? I would think with your 460 you would probably want a TKO 500 or TKO 600? Although, a friend of mine is running a 3550 with his 427.
I believe it is your second gear syncro. That is the same way mine behaved when it went out. Part is cheap but the labor will cost about $150 if you pull the trans yourself. There is a shop in Detroit that builds the TKO and also does race versions.
Clois
"Let's roll"
"Be part of Something Good
