  #37 (permalink)
Old 07-02-2007, 05:55 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
This is a picture of the differential breather hose where it goes through the trunk paneling to connect to the catch can which is in the trunk. The breather can is now mounted up high in the trunk. The hose is not yet connected to the 90 degree bulkhead fitting in the panel as you can see the hose (too long and yet to be cut) is still in my fingers. The hose and 90 degree bulkhead fitting must be oriented the same way they are oriented in the picture or they will interfere with the travel of the rear upper control arm at full bounce.
