  #74 (permalink)
Old 07-03-2007, 05:43 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Here are some close up pics of our billet aluminum Tremec TKO 600 transmission adapter mount. This mount allows you to put a Tremec TKO 600 transmission in our Kirkham 427 KMS/SC. It will also work on CSX cars and on original 427 Cobras.
In this picture, the mount is positioned as if the engine were toward the right and the differential is to the left. The two triangular tabs you see are welded onto the frame. There is NO reason to remove the original Top Loader mount. The triangular tabs mount on the REAR of the cross member whereas on an original Cobra the Top Loader mounts to the FRONT of the cross member. The do NOT interfere with each other.
